Chevy/GMC Trucks \  88-98 to lay on 255\35\20 in front
views 335
replies 14
following 12
deflaytedwayz2   +1y
what all is involved in laying the truck on the frame on a 255\35\20. how tall should the top and bottom cups be? i cut for the tierods already, cut for the lower control arm to clear on both sides. and also trimed the tabs that hold the upper control arm from making it lay. i have 3 inch top cups and 2 inch bottoms. and the truck isnt laying. i also have 2 inch spindles its about 1 3\4 to 2 inches form laying... am i missing something? thanks in advance for any helpful info
deflaytedwayz2   +1y
bump:
STUD1Y   +1y
take an inch out of both cups.
check to make sure your exhuast isn't catching on the ground too, and make sure you're not hitting your fenders with your tires already.
toreadorxlt   +1y
yup. what jey said about the exhaust. if you havent raised your y-pipe, i guarentee you that it is holding you up.
TuKnRaiL   +1y
Yeah exactly what Jey ansd Steve said. My exhaust was hittng just cut it and raise it up that prob whats keeping you from laying out!!!
stockfloored85   +1y
88-98 fullsize, IF cups in front and drop spindles, youll be good to go
caned96   +1y
upper ball joints may bind u might have to buy some tubular upper arms
beyond static   +1y
mine lays out on 3" upper cups and 2" lowers with everything you mentioned being cut. Only guess is the y-pipe.
JW   +1y
i am assuming you lost the inner fenders right???
rockboy   +1y
3 inch cups on top. bolt's into mounting plate on the bottom control arm. drop spindles, notched for tierod.
