Chevy/GMC Trucks \  Airbags with swaybar?
views 2301
replies 16
following 16
Morales8907   +1y
does any1 run a sway bar in front with bags? bcuz im not running one right now on my S-10 so i was j/w if it would make it ride better or ifi its even possible to run it with the height change from the bags?
TC29720   +1y
I used to have it on mine, then got rid of it after the B/D, you'll have a little more body roll but nothing major, most customers want thteir removed. Its just up to you
Morales8907   +1y
i was thinkin about it but im still not sure i prolly wont bcuz its gonna get torn apart again soon anyway but around turns sometimes my wheels squak it front i was thinkin because of the positive camber bcuz the front usualy aired all the way up but well c
YOLO   +1y
On the Sierra 1500 you have to remove them or they will eventually rub through your bag. I learned the hard way!
layingnutz   +1y
I HAD MINE ON THERE AIRED UP IT LOOKED OK BUT LAID OUT IT PIVOTED AND RUBBED A HOLE IN MY BAG SO I TOOK IT OFF AND DIDN'T NOTICE THAT MUCH OF A DIFFERENCE.
ScrapinChevy00   +1y
ive got mine still on my 00 silverado, but i had to ditch the firestone bags and get slam bags cause the firestone bags rubbed the bar. the slam bags dont balloon out when aired up.
seansmitty42   +1y
im running one on my 1500 with firestones. but im running it upside down so it works awesome.
deflaytedwayz2   +1y
ive always took them out because it allows you to hit better sides. but since i did a 2link in my hombre i put it back in. i think it rides better with it in on a 2 link. with it out i could drom a front corner while going around a turn or slowing down and pull a rear wheel off the ground, but that stresses everything so i stopped and reinstalled my swaybar
Stock Sucks   +1y
My truck had the ZQ8 suspension which is basically Hotchkis and i still got the front sway bar on. It rides really good and corners awesome. It also helps cuz i still got the fenderwells and it helps keep the tires from rubbin. I wish i had the rear cause it rolls more than i like....but try taking it off then if you dont like the way it rides put it back on...thats what i did
Stock Sucks   +1y
Ohh, make sure you get shorter end links
for the sway bar or it will hit the frame when you try to lay out
