ok got all my shyte wired up but i am getting feedback through my speakers when I hit the switches it is grounded and the power is coming from the cig. lighter. need to have it fixed quick gotta go to ludikrs in the morning.
come on i know the top dogs are on this site please help.
run a search happens all the time
double check the grounds or you could run everything backwards to get the pop out. run the grounds through the switch box and fuse wires going into your valves. guaranteed to not pop
Most times when people get feedback they have the valve grounds going to the valve body, or ground on top of the valve bracket. You need to scrape paint and ground to the frame with a star washer.
ANother way to get rid of ground loops is to run a wire from the switchbox ground to the valve grounds. Leve them grounded just as they are, but add the wire between them.
