need valve help asap please!!!!!
droppedB22
ok. I bought two gc 450 valves about a year ago. I never got around to putting them on till last night. Well I wired them and everything and the valves do nothing. I got them brand new from a buddy of mine. I tried switching the wires around and still nothing. any Idea's????
cdndragrr
are they properly grounded?
tukin
yep check the ground 95% of electric probs are a ground.
droppedB22
the grounds are good. Could both valves be stuck shut?
bdroppeddak's avatar
bdroppeddak
$100 says you are using the ||||-- lookin prong, use #1 and #2 (the top 2 smaller ones on the coil)
bdroppeddak
and it dont matter which is ground.
droppedB22
I am going to check that right now. I want to clean out the valves thou and take them apart. What can you use to clean those out?
lowrthnu92's avatar
lowrthnu92
mineral oil , or some kind of all purpose oil
bdroppeddak
be careful when you are takin them apart that you set the o ring in right befor you put it backtogether, or you will have a bag leak, and if you pinch the oring it will prolly stretch.
bdroppeddak
i mean a bad leak.
s10
last post by baha +1y
