4 link on ram 1500
U
4 link on ram 1500
leakyvalves
chassis tech 4 link when airred up rear end shifts to pass side panhard bar problem need help
cantlooswit22s's avatar
cantlooswit22s
its goin to shift on you no matter wat you do.as long as the axle is centered wen layed out,you should be ok.thats wat i HAD on mine.
olskoolpup
increase the length of the panhard bar and itll reduce that condition. however, the only way to eliminate it is to use a different style of locating system. i.e. watts link
cantlooswit22s
or a triagulated center
slammed97ram
i have the same set up like he said you can adjust the panhard to be center when its laid out
periportfd
The longer the panhard the less pull it introduces, but no matter how long it is it will pull and push along its arc.
