shock trouble.....
LaYeDOuT93@aol.com's avatar
shock trouble.....
ib_draggin's avatar
ib_draggin
ok im havin trouble finding shocks the compress lower than 11 inches for my truck, my shocks r in the stock position and they have the ear piece at the top and just the hole for the bolt at the bottom. can someple give me a site to go to where they have specifications or a part number or somethin, any help will be apprciated
Bentlay's avatar
Bentlay
i got nitto drop shocks for my toyota... on my last truck i had rancho 9000x shocks, they have a full range of sizes and they are 9 way valves, go to (checker/shucks/cragen-dependin on where u live) and ask them.
framescr8pintoy's avatar
framescr8pintoy
im using rancho rs5000.. dont remember exactly the size.. but they are freakin short.. part numbers are 5601, and 5602 probably find the specs. on ranchos website.
JPerry's avatar
JPerry
I use Belltech and they work fine...Just get the right specs for your model... Go with Bilstien, or air ride shocks if the Belltechs dont work!
papaburgandy
go to your local Pep boys and buy some Gabriels, not the airshock ones,the Reds,50/50shocks(can be mounted either way) there cheap, they work and Pep boys can go by what you need they have all the measurment, they dont need vihicle specific, this is about the only thing pepboys sells that i buy, except for those really cool euro starter kits, that give you 10hp on vinyl alone...what a deal
ib_draggin's avatar
ib_draggin
i can find them low enough just not wit the lil ear piece at the top mount, its pissin me off
deflaytedwayz2
if you have an s10 i feel you pain, i found some short ones but not short enough, so i ended up extending my lower mounts by like and inch and then installed the shocks. i dont have a problem now and it rides great. but i think they are both going out. they are leaking from the seals... its cause cause the shocks are fully extended b4 the suspension is able to lift 100% but i have a warentey on them so all i have to do is exchange them out for ney ones
jmn444's avatar
jmn444
go to gabriel.com website, download their catalog, around page 300 starts the specs sheets that show the type of top and bottom mounts and extended/compressed lengths.
ib_draggin's avatar
ib_draggin
thanks guys, any one else got some info?
bdroppeddak's avatar
bdroppeddak
call monroes tech line give them the dimensions and the end styles i think you can find their # on their site, thats who i use when i need a shock for a custom application.
s10
last post by baha +1y
