Chevy/GMC Trucks \  S10 Transmission Crossmember
views 1315
replies 8
following 6
EL TUBBY   +1y
I'm working on a 2001 S10 standard cab and was wondering what a good solution was to the fact that there is a plate with long bolts hanging out of it that keep the frame from laying out. I dont want to have to buy one i would like to just fab something. anyone have any pics of what they did or ideas?
brown and down   +1y
take off the triangle mounting plate, get a drill bit a little bit bigger then the bolt holes and enlarge the holes about 1/4" deep. then get some long allen boltswhose heads will sit up inside the frame. as for the actual crossmember hanging down, DRAG IT OFF!!!
AVTekk   +1y
check out the how-to i wrote just for getting rid of those bolts..
http://www.s10forum.com/forum/showthread.php?t=199196
EL TUBBY   +1y
cool. thanks for the info. i took my die grinder with a burring tool and made the hole a little wider. it would have been a pain in the ass with my long drill and bit. i would have had to get the truck way up there. its done now though and looks clean.
brown and down   +1y
avtekk is the man
97juicedGMC   +1y
or you can just by the crossmember from devious customs the 2 bolt studs that hang down on the driver side right? if so devious makes a crossmember for like 120 bucks and the bolt are counter sunk into the frame and sit completely flush.
DaGreenMonster   +1y
or u can just go to home depot, spend a few bucks on allen head bolts, and ur done
555   +1y
WRONG, well first im not sure what motor he has but its prolly a 4 banger which last I checked devious did not make a crossmember for(been a while) and b u still have to enlarge the wholes bigger with the bolts given. At least it was like that on my old v6.
97juicedGMC   +1y
please dont tell me im wrong if you dont know what your talkin about , i bought it for my truck so it does exist and it was a 97 4cyl 5 spd reg cab shortbed , comes pwdercoated its 120 bucks , devious dosent advertise it because there site hasnt been updated in 3 years but ive also seen it in minitruckin tech sections and in the devios ads, im really not tryin to be a dick here but the guy already rigged somethin up so its done. mission accomplished
