Air suspension HELP!!!
layin-frame-95
On my way to work this morning, I hit the switch to fill the rear of my truck and NOTHING!!! The dump works, but not the fill. I'm running an Ekstensive Metalworks bag setup(Done by them). What all could be wrong? I didn't have time to look, I know it could be the switch, but what else could it be?
Thanx in advance,
Rob
layingnutz
SOUNDS TO ME LIKE ITS THE SWITCH BUT POSSIBLY THE VALVES COULD BE STUCK. BUT IF BOTH ARE DOING IT IT'S GOTTA BE THE SWITCH MINE DO THAT ONCE IN A WHILE. HOPE THIS HELPS A LIL
draggindakota's avatar
draggindakota
could be too much pressure. I had a pressure switch go bad once & filled my tanks to about 225 psi and my fills wouldn't even open untl I dropped the tank pressure.
BI
Bagged iLLuZion
switch.
preasure.
wiring.
grounds.
railmaster
so did you rail that bitch all the way to work ????
layin-frame-95
Sorry Guys,
I left out some info. The fill switch worked until right before I got to work.
Rob
layin-frame-95
Does anybody else have any ideas what could be wrong?
down2earthdawg's avatar
down2earthdawg
your truck doesnt like going to work?
hahhahahahahhahahahahhaha
bigblueon22s's avatar
bigblueon22s
valves are stuck.. maybe, pour a little lube in the inlet and work the switch back and forth sometimes they just need some carresing, lmao
sadexcuse4s10
check the electrical connections to the switch and valve, sounds like a bad ground to me
s10
last post by baha +1y
