Full Size Truckin General \  My 1955 International, Rat Rod, Bagged!!!!
views 810
replies 12
following 13
fortheboyz   +1y
The rear chassis is from a 1967 T-Bird from front cab pillar and pillar forward is a 1967 merc. marq that has front disc brakes and a 429ci.. Big Block that came from the factory with 450+ h.p and 500+ tq. Has a elderbroke 4bbl carb The front is fast and will jump off the ground about 4" at 250 psi. but the front is all big block. The back is air shocks that the fitting where drilled from 1/8" to 1/4 in" for a little faster. It has a nine gallon stainless steel air tank with 450 psi valves.
Bagged iLLuZion   +1y
Pics?
BK2LIFE   +1y
rear chassis is from a what?!?! you need to post some pics.. and for that 450+ HP 429.. hahaha what did you get it out of? cause the only factory ford motor with specs like that is and was the 427 SOHC or sock motor as its known.. sorry i dont meen to talk crap or nothing, but post some pics.. i meen cmon man airshocks? WTF> we havent used air shocks since the early 90's....
cantlooswit22s   +1y
PICS PICS PICS!!!
BaggedB22   +1y
I saw this truck on ebay, Did u just buy it? If so its not really yours because u didn't build any of it...
Bryce Lively   +1y
Originally posted by BaggedB22
Heres the link if it works, http://cgi.ebay.com/ebaymotors/International-Harvester-International-Custom-1955-International-Rat-Rod-Custom-Low-Rider-Air-Bagged_W0QQitemZ4570407751QQcategoryZ31846QQrdZ1QQcmdZViewItemhttp://cgi.ebay.com/ebaymotors/International-Harvester-International-Custom
it doesnt
lowrango   +1y
just type in # 4570407751 in the search box. it'll bring it up
bagged92   +1y
