Whats a good relay/starter solenoid for my compressor
11 following
Twotipped@aol.com's avatar
Low_SST's avatar
Low_SST
I have been using a regular bosch style relay but it got moisture in it and it fried itself somehow, so i was thinking and i decided to go and buy a starter solenoid relay and see if that would do the trick but its running pretty hot and it doenst like working. I wanted to get some ideas as to what would be a good switching mechanism that is sealed from the elements and will be able to be mounted under my bed.
Douggiefresh's avatar
Douggiefresh
None...use relays...Dont waste your time with a starter solenoid.
Low_SST's avatar
Low_SST
thats what i was using before but water corroded it so i was wondering if there was a sealed option. I had to drive the whole way back from esob without nitrogen or a comrpessor.
DBLT8K's avatar
DBLT8K
i hear old ford solenoids are the way to go since my compressor won't run off of a relay without burning it up
sadexcuse4s10
stinger 80 amp solenoid
do a search on ebay, you can run 2 comps off one of those things and they're sealed
juiced92toy
We use a battery charging solenoid...like the ones pheonix gold used to sell but a generic type. $18 Canadian is what we pay for them. Good for up too 80 amps.
Douggiefresh
how many compressors are you running? Are you running an in line fuse holder. You should have no problem running relays. If they are getting wator corrosion try wrapping them up in some electrical tape or mounting them under your bed somewere they wont see the elements. I used a solenoid out of a ford bronco. I went through 3 of them and they all sucked. I have had the same relays for the past 2 years now and they work great.
Low_SST's avatar
Low_SST
the big thing with the relays is not their peak amp rating but what they are rated to handle continously. I wanted to find one that was good to use contiously for a long time.
Low_SST's avatar
Low_SST
i have a single thomas 337 and my relay worked great until it died. im just trying out this solenoid and if it dies ill just return it.
Bentlay's avatar
Bentlay
I have a 100% duty 60 amp sylanoid. I got it from a truck supply store, ran me about $30... been runnin it daily for a year. No problems yet. Also make sure u have a fuse b/w the batt and relay...
s10
last post by baha +1y
