gaskets
gaskets
loweredtoy
when reassembling a motor, which gaskets and where on them needs some silicone sealant? Also what is the best sealant to use.
truck action's avatar
truck action
Get a complete gasket set, & use high tem stuff where called for!
3tcrob
Just get a tube of FIPG from Toyota about 12 a tube
loweredtoy
ok, i have the gasket set, but which gaskets need sealant on them and where on them?
3tcrob
On the timing cover gaskets and the oil pan gaskets just put a thin layer to help seal it also on the water pump gasket, The oil pump is a rubber o-ring and you dont need it on the head gasket the VC gasket the intake or the exhaust gasket(wouldnt hurt on the intake)
loweredtoy
ok, someone told me to do the corners of the head gasket by where it meets the timing chain cover
m_i_zombie
Get you a haynes or chilton's manual and it will tel you everywhere you need to apply it at and what tourqe specs you should use.
johnny5's avatar
johnny5
this is correct
loweredtoy
thanks for the help
3tcrob
I have never had to do it and never had a problem with it leaking there
