Dodge Trucks \  do i really?????
do i really?????
Dodge Trucks Make Specific
views 430
replies 15
following 9
1 LoWfUKn RaM   +1y
do i really need to shorten my rear end for my body drop am run 20s dont know wad size yet but 20x8 i would say ..if i have to shorten it ama have to do it but i really dont wanna ..if not ama swap to a f150 rear end ...input plz
Jance Customs   +1y
Edited: 8/29/2005 9:04:03 PM by jancecustoms
I don't think you have to shorten your rear end. I do know you have to cut out part of the fender flare lip to tuck them. I don't have bags but I know a guy that has 22x9.5 and he has no problems with the drop.
DougyFrisch   +1y
get the right offset and u should be fine, maybe
Jance Customs   +1y
Yeah I think he has 15mm offset but I am not for sure about that. If you have 8's I don't think you will have a problem.
ramslam1998   +1y
ive got a ford 9 inch in mine its 4 inches shorter than stock you can look at my offset and 4inches more narrow rearend is kinda close (76 ford truck) bolt pattern is the same and my truck is stock floored on 20 soon to be 22s
Low_SST   +1y
I would just get a ford 9" with the same boltpattern and use that. It will probably be cheaper and if you ever decided to change gears i bet they would be cheaper. Im thinking about doing that myself down the line.
1 LoWfUKn RaM   +1y
wad would be a good ford rear end i know a 94 f150 is shoter and same bolt pattern and a 74 ford f150 too right and wad else
Low_SST   +1y
do you lay rockers with that bd?
1 LoWfUKn RaM   +1y
^^^ yeah i need to know that too
ramslam1998   +1y
yeah im layin pinchweld and its got that wrinkled to hell my truck is backhalfed too which means i also have stock depth bed floor as well as cab floor it sets up in the front a little being that im waiting on my arms from BYC
