Nissan Trucks \  truck wont charge
truck wont charge
Nissan Trucks Make Specific
views 205
replies 6
following 5
FirstCoast Kreation   +1y
ok i have an 89 nissan hardbody.4cylinder 5 speed manual...ok,itll crank and run.but if i drive it,it will sputter and want to shutoff.then if u turn it off it wont crank back up.but if i jump it itll start.the volmeter is at 10,i just had the alternator testd today and its fine.i cranked it up after i put if back on and it ran the i shut it off and it wouldnt crank back up...and its a new battery,ive tryed 2 diffrent bbateries and it did the same thing..please help me im so stumped on this
help..lol..im stumped
555   +1y
does it sputter soon as u put it in drive?
layinframe2200   +1y
check the cluster of conections that are all tied together on your positive terminal on your battery. my truck does the same thing i had to change the terminal in my nissan and it took care of it. it will effect your chargins system and your head lights.
lowdyme   +1y
you also might want to take out the battery and bring it to a auto place to have that checked because over time the diodes in the battey go bad causeing it to not to keep a charge
dwnlowx   +1y
if i were you i would not drive it because it can get alot worse and check all your wiring on your truck ,asin fendr weels any were they might be rubing
