Air Up pressure
N
Air Up pressure
TukinRange
I have 2500lb contitech bags up front in my ranger, My question is.. Even at 140psi my truck aint liftin over my tires, bagged/bodydropped. Do the rest of you ranger owners have to have this much air to lift your trucks?
rangerlayinrocker
how are your bags set up in the front? i konw i have 2500 lb bags in the front of my ranger and i dont get alot of lift either but you can run some like tubular mounts and put 2600 lb bags up front and you should get enough lift thats what we plan on doing to my ranger to clear 20s up front
deflaytedwayz2
get slams, you will gain lift. also make sure if your running shocks up front that they arent reaching there limit b4 you get full lift
kdisystems
I have 2500lbs Firestones and with the mustang II IFS and v8 I get 8" lift at about 85psi
dragwithme's avatar
dragwithme
my truck has the same probelm i think they are just heavy in the front
Dejavu's avatar
Dejavu
i run 150 in the fronts to clear 20's....stiff!!!!!
bodydropped85's avatar
bodydropped85
yea i have slams on the front of mine nad can barly untruck my 18s...
tuckin eh's avatar
tuckin eh
I throw 70 psi up front on mine and I can untuck 18s with my 2600s. hell at 140 my truck is maxed out full lock and the bags are fully extended.
