Single Row and double row
N
3tcrob
I just won a double row LC chain kit with adjustable gear(he says)are the double row chains and the single row chains the same? So if I got a double row timing cover it would be bolt and go? I know the cams will interchange but dont know if the height is different from motor to motor
Thanks
nook's avatar
nook
There are 2 different R versions, in the beginning 75, the 20R was a tall deck, tall head design, used a dual row timing chain setup, in 81 the 22r came along, still the TD/TH design, and still had the dual chain set, around 82 they started using a single row chain with the same TD/TH. About mid 84 they came out with the newer version or lazer block as many refer to, it had a shorter deck, shorter head, and used a shorter single row chain setup, they won't interchange between the two versions. The timing cover was shallower, used a different oil pump and oil pump drive spline, and also the valve cover was changed to the coffin style square nose.
Depending on what year dual chain setup you have will determine which model engine it will fit. LC does make a dual chain conversion kit for the later engines, it is basically an early timing cover remilled to the shorter deck height, the top bolt holes filled and redrilled, uses the early dual row timing components, oil pump, and drive spline but requires a custom chain because of the shorter deck height.
If memeory serves me right, been a while since I counted them, but the early engines used a 98 link chain and the later a 96 link, don't quote me on that, but should be close. Also if you use the dual chain with the later square nose valve cover it will require trimming inside on the oil deflector for clearance, the older bull nose covers fit with no mods.
Hope this helps. PS. make sure to use some blue loctite on the adjustment bolts on the adjustable gear to keep from eating one down the timing cover after dialing in the camshaft.
oldsklminitrk
Damn it man......you explained it on a dime!
3tcrob
Sweet thanks for the info, I e-mailed th guy yesterday and no reply yet I am going to find out if this is the conversion pr a pre 84 chain kit
holcombe347's avatar
holcombe347
hell yeah, my head hurts after learning all that in one sitting. lol.
jeremycracker
NOOK is the shit!!!! i'd like to build some motors with this guy, i think i could learn alot! i have an AA for mechanics, but it was all general info. (which is still really important) but i'd like to learn specifics about the 22R, especially the efi side. because mine annoys the shit out of me sometimes.
nook's avatar
nook
Glad the info was a help to ya, good luck on getting your chain deal straightened out. The 20 and 22r's are a basic little yankee engine once past the plumbing on the carb or EFI, they adapt well to most upgrades and although they never will be a ground pounding big block, they are a kick to tweak on and see what can happen.
nook's avatar
nook
[quote="3tcRob"]I just won a double row LC chain kit with adjustable gear
Just wondered if you ever got the chain set and was it going to work for ya?
I,m in the building (slow) process now, putting together another engine to replace one that doesn't need repacing other than why not if I can squeeze a few more ponies out of it
