clutch master help
12 following
clutch master help
hyboost
do'se anyone have any pics or ideas how to get the clucth master under the dash and what booster to run so i can tub it for 20's thanks
LSCivic
Hit up Sadistic Iron Werks on here (sadisticiron). He knows all about layin' Yota's out on big rims. If he can't help you then I don't know who to ask!Steve SoCal
GFreeman's avatar
GFreeman
heres how my buddy did his. he used a booster from an earlier year yota.
GFreeman's avatar
GFreeman
opps i didnt see you said under the dash, but his truck was the same year and on 20s so it may help.
sadisticiron's avatar
sadisticiron
thanks steve i appreciate it
ill send you a pic of the master hyboost
and i use the stock booster on 20's b/d
sadisticiron
1lonisn
i put mine under the dash.
sadisticiron
i put it outside so the a/c vent tubes work like oem with the a/c on
LSCivic
Damn, b/d with an A/C... Best of both worlds right thereSteve SoCal
Severed701's avatar
Severed701
i just moved mine up on both my yotas..i dont see what would affect the a/c since its on the other side..but anways the ac still works on both mine too..as for the brake booster im using a geo metro one on my chop top toyota..but im considering changing out out to a hot rod one or something cause when i do my rx7 irs i duno if it will be enuf for 4 wheel discs..i'll find out i guess....its just as easy to move your stock one over a little bit as well...
