Toyota Trucks \  pleese help urgent
pleese help urgent
Toyota Trucks Make Specific
views 312
replies 19
following 14
mr.safety   +1y
we need to get this truck rollin 4 summerslam tomorrow. its an 89 toyota ex cab with v6 and auto tranny. when we turn the key it will fire and then immediatly die. also wuld anyone know if there is an emergency fule cut off that might have tripped. thanx for any help
dubrocker04   +1y
give it gas and keep it running till it warms up. then see if it will stay running.
H8MENOW   +1y
DOES IT HAVE A MASS AIR FLOW SENOR? IF SO IT MIGHT BE TURNED THE WRONG WAY. THE ENGINE WILL NOT BE GETING AIR THERE FOR DIE.
mr.safety   +1y
bu bu bu bump
mr.safety   +1y
ba dump-a-dump
TacoFel   +1y
check to be sure the igniter is properly grounded.
madmatt   +1y
Check all the wires man. I once worked on a ranger that would start and run for like three seconds and die. It turned out to be a loose spark plug wire. The computer won't let it run if it senses somethings not connected.
Ashton   +1y
make sure you have Blinker fluid. I allways check that frist. lol
mr.safety   +1y
i checked the blinker fluid it was a little low. i topped it off but shes still a no go
mr.safety   +1y
buuuuuuuuuuuuuuummmmmmmmmmmmmmmmmmmp?
