o4 2wd 1500 ram , is flipping the rear spring over a good easy way of evening the truck out ? or would be better to take one leaf out ? , im not a truck guy and this is for my buddy , any help is aprecciated
Low_SST
the rear flip drops the rear 6" which means just to level it out would need to drop the front 4", if you only want a small drop in the rear to level out then you can use spring clamps from autozone because they will lower the rear 1.5"-2"
