Bagged accord
Bagged accord
dtpntexas
I know nothing about bagging Hondas, and i was wondering can I just bolt struts in place of the springs? And if i do will it lay frame?
CiViS300
If you "know about bagging Hondas" then I dont think you would be asking this question. Just my . Yes you could just bolt in a air strut but it will not lay you that low, the next option would be to use cylinders which will get you lower but might ride a little ruff, your last option would be to juice it which will prob get you the lowest and best ride. None of these will bolt in and lay you out completely without doing some cutting and reworking.
TC29720
And you should know that you don't have a frame. If you're lookin to go REAL low, go with cylinders, they strut bags won't get you as close as they will to layin
dtpntexas
Thanks,I didnt know about the frame becuase i dont own the car yet, and its my first accord. Would something like the MIC Air Cylinder kit be good start? And does anybody have a picture with this done? (ive done many searches but people are very subtile on details, and its hard to figure out what they have done)
3day's avatar
3day
EAI cylinders, this is mine layed out
HS
hybrid showoff
everything should be direct bolt on, and with cylinders when dumped u should be about 2" away from the ground(thats what i was) but to lay out flat your gunna have to raise the shock mounts 2". thats what i had to do anyway....wish i had a camera, i could show u pics of mine. laid out without a kit and raised shock mounts....involves a lot of work though.
HS
hybrid showoff
i forgot to add that u will have to cut some of your innder fender out in front also depending on wheel size(im on 19's)
Douggiefresh's avatar
Douggiefresh
Do the MIC kit. Make sure you get the SMC cylinders if you do.
N
NVR21O
nice ride dude
dtpntexas
Thank you All!
