Chevy/GMC Trucks \  under the frame brake booster
views 220
replies 9
following 7
layingframe   +1y
under the frame brake booster does any one make them do they have them for a 94 s-10
madmike   +1y
http://www.s10forum.com/forum/showthread.php?t=187711 go here, a guy put it under his dash
layingframe   +1y
all that was is about engine kocking
built to drag   +1y
its a street rod thing. any street rod mag will have them. some older vehicles came stock with them. a decent one will set u back around 300 bux. it may be cheaper to check out race car places hope this helps
bdroppeddak   +1y
good luck fitting a brake booster underneath an s10...........
bdroppeddak   +1y
but i guess you could have it underneath the bed might have to fight the gas tank and move it.
madmike   +1y
huh?
loudciv   +1y
Edited: 9/1/2005 5:59:12 AM by loudciv
k-otic kustomz fit one under a traditional doored d50. just made an access panel under the seat.
DawgsledMazda   +1y
make your own, just mount the booster in the back or under the floor and fab the rod to push it with. mines in the back near the rear axle.
DawgsledMazda   +1y
make or get a floor mounted pedal setup and they use a long rod. easier than it looks and it keeps the firewall clean. this can be applied to the clutch as well.
I made my pedal assembly and used 5/8" solid rod to push the 6" diameter Geo Metro booster and master cylinder. Im running front and rear disc brakes with inline check valves and a wilwood adjustable proportioning valve.
anyone needing advise on this please let me know. also check out speedwaymotors.com for the pedal assemblies.
