Ford Trucks \  2600lbs on a ranger?
Ford Trucks Make Specific
views 146
replies 5
following 6
TukinRange   +1y
Will 2600lb bags fit up front of a 98 to present ranger? rs72's if you must know.
awj81   +1y
I not sure if they will fit, but I am sure that someone has tried it before
tuckin eh   +1y
I got airlift ones up front on mine. cut out most of the spring pocket and there's room. I'm not sure on the compressed dia of the slams but I think you'll be okay with rollplates.
JFcustoms   +1y
i got suicide doors cups and i had to re drill the cup holes to get the 2600contitech bag towards the spindle and i had to cut a lot of the spring pockets side on the frame out so the 2600 wouldnt rub on anything and you have to chop 2" off the top bucket and also i cut like half the height of the lower control arm off and replated it so it can lay crossmember on 18's...yer gonna have to re-do the tie rods linkage to get it to lay and lift good...good luck man, i wish i never started bagging a ranger, they suck
couldbelower   +1y
i got 2600s....
hotrodcarey   +1y
it takes soem effort to put 2600 up front. i will be putting rs72's up front when it comes outa the shop. its def. possible
