Lowered Engine mounts
austlowlux86
Hey guys, Ive done some searches but i cant find the pics of the mounts that seth made up to lower the engine 1". I want mine a little lower to give a little more clearance. also do u need to section the oil pan or is there other ways around it?
Thanks
holcombe347's avatar
holcombe347
Im pretty sure you have to section the oil pan and modify the drag link when dropping the motor that much.
kdcgrohl's avatar
kdcgrohl
Seths motor mounts(after clean up and powdercoat). you can probably slide on the drag link mods, maybe a washer or two to shim it, but the oil pan is a must.
twisted minis's avatar
twisted minis
I make them in 1" and 1.5" drop.
