Isuzu \  anybody mounted byc lower arms
Isuzu Make Specific
views 197
replies 4
MDcrew208   +1y
i just got my lower arms from them and they're different then i expected... sorry this might be a little confusing.. i figured i would just have to mount them in the stock spot then see where i would need to weld the tabs for the stut rod eliminators (i figured there would be 2 tabs for each side) but theres only one and a tube that looks like it should go in between where it bolts on stock and where the strut rod eliminator spot is but that tube doesn't quite fit.. i can probably figure it out but hopefully someone has them installed.
fatnutz69   +1y
can you take a pic of all the stuff you have there. maybe if we see what you have
DawgsledMazda   +1y
the main bushing on the arm mounts in the stock location. then you put the long bolt thru the main bushing hole and then install the long tube on that bolt and then weld it to the frame. then the smaller bolt goes thru the small bushing and into the other end of the long tube. the 2 small tabs are for shocks. use them if you need to or if you are not running shocks then dont use them. FYI shock mounts usually work best halfway between the bushing on one end and the balljoint on the other.
call me today if you need more info on that.
call my cell since im closed today
469-682-8621
MDcrew208   +1y
thanx for the hella quick reply mike -- it will probably be a week or two before i get them mounted (i have some other stuff im working on) but i'll give you a call if i have any more questions-- the main part that threw me way off was that those small tabs are threaded to where the small bolt threads into it so i thought that they had to be used.
gtpunk18   +1y
hey Scott are you still workin on the other parts/ door laying Isuzu
