Light weight fly wheel (pics!)
psycopathicryda
I just added a light weight flywheel and stage one exeddy clutch.
It wasnt cheap but when your running the stock clutch and flywheel with over 270,000 miles it helps to change over. I noticed a huge diffrence. mainly because the clutch was slipping for the last 15k.
here are some pics.
first start with a clean truck.
Then take out the drive shaft.
after removing the drive shaft remove the shifter and covers to the shifter.
I would also say if their is no rush do a short shifter. I decided to wait till later. then remove the transmission. you will use mainly 12, mm 13mm, 14mm, 16mm, 18mm, and air tools kick ass!.
Now is a good time to do a rear main seal or do some cleaning. I also cleaned my trans when I had it out and didnt take any pics sorry
inspect the old clutch. I found the springs in my clutch were worn and broken. my flywheel was only brushed in 3 spots i could have machined it but decided to go light weight (9lbs).
check out that new flywheel and keep red bull on hand to keep you motivated.
here is the new set up see for the last time till I brake that. be sure to torque everything to spec.
now look at the mess you made clean that bench (or toolbox). this was only half the stuff i also used a good friend to help pull the trans (not pictured).
onelowminitruckr
Looks good man, now lemme drive it.
holcombe347's avatar
holcombe347
that cool dude, what does it do on the freeway? does it turn at a higher rpm than before?
truck action's avatar
truck action
I've run one for the last two years, great response! Engine spools up fast!!
m_i_zombie
These babies are worth every penny. The response you get right from the get go is awesome.
phatboislim
that's exactly how my clutch looked when i replaced mine...except it looked like a rotor lol
how much did the whole clutch/flywheel combo run you?
psycopathicryda
Well to start it doesnt rev higher it gives a great response. it really just takes alot of lag out of the accelleration.
The whole combo was about 325 for the flywheel and 100 for the clutch. I got the flywheel from this is the cheapest i found the flywheel. All other sites are 350.
