six to five lug help
utk86@yahoo.com's avatar
ahab's avatar
ahab
I need to know what is needed to put a toyota axel under a nissan frontier. The axel will be four linked so the only isue is the drive shaft. thanks
bdroppeddak's avatar
bdroppeddak
take your nissan shaft and a toyota pickup shaft and have a driveshaft shop mate the yota yoke on the nissan shaft, before you go, its a good idea to go ahead and put in the rear end, so you will know how long the shaft needs to be. your brake lines will hook up to the yota rear, only thing im not sure about is the e-brake.
ahab's avatar
ahab
thanks man i think the ebrake will probly be ok. is this how everyone does it or is there another solution?
ahab's avatar
ahab
There are alot of people running toyota axels is there a different way to do it?
SICKANDTWYSTED's avatar
SICKANDTWYSTED
i pulled the axles out of my nissan and had a local machine shop redrill them for $250. saved me a lot of work cause im lazy like that lol
ahab's avatar
ahab
what about the drums?
SICKANDTWYSTED
redrilled them at the same time
s10
last post by baha +1y
