removing dash in a 97 s10
N
blackrado
does neone on here know where i could find a guide that tells you how to get it out???
liljlowrider's avatar
liljlowrider
dont know where you can find a manual to do that but its not really that hard .. you just need to start removeing screws there is alot of them but is really fairly simple.. good luck ....
jaredmxg's avatar
jaredmxg
all u half to do it pop all teh front pieces off. take the vent on the dash off there are little screws there. behind the glove box there is like 3 big wiring harnesses. you should drop the steering colum with 2 bolts. undo that wiring harness. there are a couple if you look above the clutch lever or brake lever there is a good size one there. Take the speaker covors off on the dash there are a couple there and once all that is done the dash will hindge down towards you on its pivot points near the door jamb. Make sure you clearly mark with masking tape what wires go to what. thats all the help ya should need
no1lowr's avatar
no1lowr
defintely do that last suggestion with the tape!! ONCE that shit is off u will have wiring mayhem and if u dont know where they go ull be S.O.L.
