trans. question
trans. question
chopedmazda
i have a 4wd auto trans. and i want to go to 2wd can i just undo the transfercase and use the auto trans
kdcgrohl's avatar
kdcgrohl
attached to the back of the trans.
drive shaft no el fitto.
m_i_zombie
Like most of the Toyota transmissions you can if you install a the rear tailshaft housing. Your transmission won't have a rear housing since it mates up to the transfer case.
twisted minis's avatar
twisted minis
They are different. I've rebuilt both in my transmissions class.
Post was last edited on Jun 29, 2007 11:14. Edited 1 time.
chopedmazda
so thats a no seth
twisted minis
The 4WD is a lot bigger, longer really. You could try it, and might just end up with a shorter driveshaft. But I kind of doubt it would work. But I could be wrong.
chopedmazda
ok then ill just look for a new trans.
