steel frame table
14 following
steel frame table
JFcustoms avatar
JFcustoms
where can i get one in southern cal. im talkin about the flat rectangular steel frame table i can set my frame on and clamp it down and start welding it and keep it straight
bertristerf150hd avatar
bertristerf150hd
make one
insaneautoconcepts avatar
insaneautoconcepts
Any steel shop. Some assymbly maybe required! LOL You will probably have to make one like Robert said. I did.
whynotfab avatar
whynotfab
how much does a big ass plate of steel like that usually cost? lol
i heard something about a marble table being good for welding on, maybe it has to do with being perfectly smooth/straight.. anyone know?
tofnlows10 avatar
tofnlows10
i made one out of 2x3 for almost $100...2 feet of ground w/ wheels to move it
guiltybydesign avatar
guiltybydesign
I would make it out of some heavy tubing. It would keep weight and cost down a lil, and if it were a big sheet you would have a hard time clamping things down.
mtm avatar
mtm
marble? damn good luck finding a cheap hunk of that
nvrlowenuf avatar
nvrlowenuf
just go buy a 4x8ft sheet of 1/2" or 3/4" steel plate and then weld some 1/4" wall legs to it and you are gravy. as for clamping your frame to it you might as well just weld your work piece to the table so then you know it wont move.
1 LoWfUKn RaM avatar
1 LoWfUKn RaM
^^^ thats real expensive yo and heavy as hell
nvrlowenuf avatar
nvrlowenuf
true on both parts. but were i worked we had a few forklifts so moving tables wasnt an issue. you never had to worry bout the table not being able to support what you put on it.
