87 yota runs then just dies, WTF
lkrayziej@hotmail.com's avatar
lkrayzie's avatar
lkrayzie
Edited: 9/8/2005 8:41:50 PM by LKrayzie
i need some help, i got a 87 yota, just bagged not bodydropped, and its running like shit. it will start up, then just die, acting like its gettin no gas, i replaced the fuel filter and fuel pump, its a carbed 22r. it used to only do it like once a week, then it started getting worse. sometimes it will run fine, like the other day i went out and decided to see if i could figure the problem out, and it didnt do it all day, so i drove the fuck out of it. then i went to hop in the next day, and it starts up, 2mins later dies. if i pump the gas it almost stays running. i cant figure it out, maybe carb? and i just did a tune up to it too, and adjusted the timing, any help would be great, thanks
2pumpchump
It sounds like your carb.m My truck used to do that and I took the carb apart and found a hair line crack in the float. On your carb, there should be a sight glass. See if the fuel in the sight glass is halfway (from top to bottom). If it is past the top, your carb is flooding. Hope this helps
lkrayzie's avatar
lkrayzie
i fixed it, after replacing the carb it did the same crap, so i pulled the line off the fuel pump, and it was dripping out, so i threw one of those universal electrics on, and boom, it ran. now ima throw a weber i got for free on it, anyone know it they are hard to rebuild?
