2001 F150 Front end
jasonmnichols@hotmail.com's avatar
2001 F150 Front end
jmn444's avatar
jmn444
OK, Just moved my battery to the bed, so I should start cutting next weekend... it's on 22's & I'll probably take it down to the trans cross member, but not wanting to truly lay frame, i want it to roll still if something goes wrong... Looking at what's still probably in the way, it looks like most of it can just be moved a little and be fine, did anybody need to lengthen wires or anything else that would take a ton of time? Any other last minute tips before I get myself in trouble with it???
bertristerf150hd
computer on passenger side fuse box on drivers side hood squirter and the bundle of wires on the drivers side just move them up and over.
Forever Draggin's avatar
Forever Draggin
depending on what rim/tire size ur running, ur tire will rub on ur brake booster, and ur gonna have to do something about the crossmember thats over the gas tank, itll rub on your driveshaft when u drag, that should be bout it. rag:
jmn444's avatar
jmn444
Not that anybody will care, but my spindles are ordered and I can't fukin wait to get this thing down
BLACKMAGICON24S
YOU WILL HAVE TO RE-LOCATE WIRES AND THE COMPUTER ON BOTH SIDES OF THE FIREWALL. ALSO IF YOU HAVE A 285/35/22S YOU WONT HIT THE BOOSTER.
ALSO, WITH THE CROSSMEMBER YOU CAN JUST CUT THE BOTTOM OFF AND RE-PLATE IT.
baggeddogs's avatar
baggeddogs
the spindles suck, dont use them...
jmn444's avatar
jmn444
tooooo late to not use the spindles, why are you saying they suck?
thanks for the tip on the crossmember slam!
22dragn's avatar
22dragn
I have the spindles on mine and it lays out on 22's with a 265/35/22. the only thing with the spindles is that you have to notch for your tie rods and will need an alignment really bad afterwards, but i found them really esy to install(took 20 min a side)but just a hint you my want to paint them before you install them because they will turn that nice rust color after a couple of days.
jmn444's avatar
jmn444
I thought you had to notch for tie rods pretty much no matter what you do to lay out... I kinda figured on the alignment, but I thought that the toe would stay about the same as long as I rode lifted up. Guess I'll find out soon! I'm running 265/35/22 so hopefully all will be well and easy....
