22r egr removal
Z
22r egr removal
minitoy89
hey everyone i have a 22r with a weber 32/36 carb and i tried to block off the egr valve but after i start it, it stalls and when i try to keep it running it smells rich, do i need to adjust timing or did i maybe do something wrong? any help is appreciated, thank you,
Zach
m_i_zombie
You have to block it off in 3 places, intake, head and exhaust/header. You may have to lean out the carb a little pending on how its jetted.
yodaforce's avatar
yodaforce
I just capped off my EGR at the 3/4" fitting where I removed the pipe that goes into the intake manifold. I put a cap on the vacume fitting that stubs out of the valve. The only problem I ever had was when the cap blew off the EGR valve when I had a minor backfire while tuning the carb and timing. All of my old piping on the manifold and the back of the head remains until I get a header.
dubvipers's avatar
dubvipers
doesn't the 22RE also have EGR stuff? cuz i pop my hood and theres vac lines all over the place and i wanna remove the stuff i dont need
yodaforce's avatar
yodaforce
With fuel injection, you can really mess things up by removing too much (ie the EGR system).
dubvipers's avatar
dubvipers
can you make a list of things that i wont need?
yodaforce's avatar
yodaforce
I wouldn't remove anything. I would probably hide some things to clean it up a bit, but the way that most everything is tied into or affects the readings that the computer recieves, removing some things can adversly affect the performance of your motor. Every one of those little vacume lines has a purpose, usually relaying information (vac. pressure, air pressure...) to a sensor or a switch that in turn sends info. to the computer, which regulates everything to make the engine run to it's best potential. If you want to remove everything, get a carb and strip everything. A carb is a relatively simple device compared to a computerized fuel injection motor. But you do lose mileage, and efficiency.
