axle wrap with 4 link!!
slammednissanhb
just put the rear air bags in, i got 4 bars running forward the top bars welded to the meatball to the top of the frame, and lower bars welded underneath axle to inside of frame, when i give it gas my whole axle rotates and when i shift it makes a loud clunk. Could this be because i have my upper bars angled outward to much???
slammednissanhb
ya thats what we checked if i have the truck off in gear parking brake off i can rock the truck back and forth forward and back, my axle rotates it moves up and down quite a bit i held all the tabs and bolts none of move, but i was thinking my top bars are really angles outward what if i had less of an angle pionting toward the cab more???
Dupa102933's avatar
Dupa102933
how are the rod ends on the 4 link bars are they all tight i don't mean the bolts but the actual rod ends
slammednissanhb
ya checked em made sure there tight too
bdroppeddak's avatar
bdroppeddak
pictures worth a thousand words, go get some.........
BdydrptS10on20s's avatar
BdydrptS10on20s
check to make sure your bolt is the same diameter as your tabs bolt holes an if you using a bolt that is only threaded a quarter distance an smooth or sleeved the rest you might be tightened onto the thread end but not tight in the tabs ... understand?
the501clique
mine did this when i stripped the threads off that go into the 4 link bar the rod end was actually moving in and out of the 4 bar
slammednissanhb
k ill dbl check on that stuff and see if i can get pics up thanks
Forever Draggin's avatar
Forever Draggin
same thing here, but is ur bolt that goes through the tabs and the bar heim as big as the hole where its a tight fit? that may be the problem
slammednissanhb
well i figured it out my lower bars where i have it bolted to the frame i had a spaced out from the frame the tube i used was bigger than the bolt so it was walking around in it.
s10
last post by baha +1y
