Yota 2.4L 22-RE I4 \  fuel cell??
fuel cell??
views 861
replies 3
watatoy   +1y
Yeah im going to be running a fuel cell i was wondering if anyone has a alluminum fuel cell with your stock pump?
truck action   +1y
Stainless tank ,using stock sender & pump brackets.
watatoy   +1y
what size tank do you have? So you just bought the tank and use your stock pump and evrything.
yodaforce   +1y
Personally I would go with any aftermarket cell but use a performance pump and regulator from Summit racing. Besides, unless the dimensions are right, your stock pump may not sit low enough or too high in the cell. Summit sells a Mallory unit for Fuel injection (40gph @ 40psi) for $149. Run an external regulator with a return port and it would be a whole lot better than running stock!
