truck leans
truck leans
slowrollin
i have an 81 c10, i put an air suspension on it and it leans to the driver side, since i saw this i put edelbrock shocks on there and it still leans but when i raise the front up all the way to 120 lbs it levels out but at ride hight 90lbs it leans . what is this , will a sway bar cure the problem
F
frshryd
maybe put the air tank on the passengers side to balance out your weight ?
SSM-Webmaster's avatar
SSM-Webmaster
Have a valve to each wheel instead of one to the front.
F
frshryd
awww, why does it do that ? wouldn't the valve stay open until the whole line hits the set psi ?
ostncoln's avatar
ostncoln
if are you running f/b only, the truck will lean to whichever side is heavier. or also if you mounted bags over the rear axle even with individual control i have seen them lean b/c the bag mounts are not in the same place on the rearend
PimpinMidgets
loose weight...or pick up a fat girl...to get the gangsta lean to the right
slowrollin
a sway bar will fix it ,right
BAGGED 68 FORD's avatar
BAGGED 68 FORD
RUN A SWAY BAR OR USE 4 VALVES UP FRONT SO THAT THE AIR WONT SHIFT FROM ONE BAG TO THE OTHER WHEN MAKING A RIGHT OR LEFT TURN.
ST Kool Laid's avatar
ST Kool Laid
gangsta lean, dont worry about it lol, i would run a sway bar or run a 8 valve system.
Dupa102933's avatar
Dupa102933
the best thing to do to keep handling best would be a 8 valve system
s10
last post by baha +1y
