Chevy/GMC Trucks \  bagged s10 driveshaft hits the cab why?????
views 486
replies 3
greendime   +1y
i just got done bagging my 97 s10 and when i lay out the drive shaft hits the cab floor pretty bad is this a common problem or is cause my pinion angle any help would be great as soon as this is fixed i can drag!!!
bertristerf150hd   +1y
one piece shaft normal
NRChopShop   +1y
on std cabs, yes it is common. make sure your pinion angle is correct and notch the cab accordingly. if you have a reverse or 50/50 link setup it will only make it worse.
Low_SST   +1y
Originally posted by minimazda5
true true true!...one ?...whats a 50/50 link setup???
lower bars foreward uppers reverse or visa versa.
