TIMING help
TIMING help
9
93yota
hey guys i have a 93 yota efi and i cant get my timing on i have tried for a long time and i cant get it is there any special tricks or sum thing any advise will help thanks guys
nook's avatar
nook
You need to use a jumper wire in the diagnostic plug jumpered across I believe the E1/TE1 connectors, don't quote me on those so check a manual to make sure those are the right terminals to jumper first, then the base timing is set like normal with a timing light. If it still is not working possibly the idle is set to fast, or the throttle position sensor is out of adjustment or not working correctly, not allowing the timing to be set to spec. Damn computerized stuff
9
93yota
ya i read that in the manual but i dont understand wat that is cant u explain wat that is and do u need to use a timing gun or can i get away by doin it manualy
nook's avatar
nook
The diagnostic plug on your 93 should be next to the fuse block under the hood on the passenger side, small little flip top box that has diagnostic printed on top, it just needs a jumper wire connected to the 2 terminals to apparently bypass the computer to set the timing, then the timing is set the conventional way with a timing light.
You could adjust the timing by ear, wouldn't have any idea where it actually was, so you would need to be cautious of the engine running hotter, pinging, detonating, so you could fine tune it as it may be too far advanced, or retarded using that method.
truck action's avatar
truck action
Use a timing lite!!
procplus's avatar
procplus
Or if you have a vaccum guage you could set your timming at the max vac you can get..
