truck dying out?
truck dying out?
S8
sickyota 808
anybody knows whats this problem, my friend owns a 92 toy with a 22RE, the truck starts fine but after driving it around the block,the truck starts acting up & just dies out on him, he waits for awhile then u can start the truck up again...anybody with any clue on why its dying out..
yota93's avatar
yota93
Maybe the fuel pump is going out,
truck action's avatar
truck action
Pump, fuel regulator, TP sensor,or a ground wire.
yodaforce's avatar
yodaforce
Sounds like the fuel filter. When you crank it up, it pulls dirt from the bottom of the filter, eventually starving the motor and shutting off. Then the dirt settles back to the bottom, allowing it to be started again and ran for a while before it clogs again. Start with that since it is the cheapest fix. If that's the problem, you will have saved alot of money, and if it isn't, then you can move on to the next part in line, all the while, knowing you have a clean filter allowing clean fuel to run through the brand new parts!
S8
sickyota 808
^yodaforce, yup i'll probally tell'em change that first since its the cheapest then work ya way till da next thing if thats not the case.. i'll let u guys know what happens!
