Air Ride Suspensions \  help w/air ride
help w/air ride
Air Ride Suspensions Q & A
views 105
replies 8
following 8
MrWilson   +1y
Well first off, I'll say HI, I'm new to this(airide) and purchased a blazer from a guy and now i have a problem, the rear(driver side) airbag on the truck fills up on its own, whether its running or not, I don't hear no air, just wondering if maybe you could help, tell me what may need to be replaced or fixed. Like i said this is all new to me. Thanks
jcordova   +1y
the valve going to the bag is sticking open.
Low_SST   +1y
you need to add a check valve between your tank and your fill valve. I would also highly sugguest getting as fimiliar as possible with your new truck so if it breaks or something you know how to get it up and going. i would also learn how to recognize wear on bags and lines.
Low_SST   +1y
jcordova   +1y
yep put a check valve on their. Call any place that sells bags and they will sell you a check valve. It's a fitting that only lets air through in one direction.
Low_SST   +1y
acutally now that ive thought about it a check valve wont work you need to lube your valve and make it stop sticking open. I would aslo recomend draining your tank and getting any moisture out of it.
lowdyme   +1y
when my valve stuck open i lubed it and everything but i still had to buy a new valve do lube it i just took the line off and drop a few drops of phnumatic oil into the opening and hit the switch a few times if that doesnt work the four screws you can just undo them and put s few drops in there
periportfd   +1y
LOL, yeah I was wondering where you were going with that.
MrWilson   +1y
Thanks guys, alot of people said this is the place to come if you need help, and i'm learning about the truck now i've only had it for two days.I appreciate all the help. Thanks
