1/2 or 3/8 lines...
1/2 or 3/8 lines...
crazeflier07
I have a 98 stang that is right now running 1/2 inch lines to the front (the back isn't done yet) and I was wondering since I am going to be running new lines when I get the back done should I stick with the 1/2 or should I swap to 3/8s? I feel like the main line I have running to the front is getting the sh*t beat out of it on speed bumps and I was thinking of running the smaller line so I don't risk popping the line one day while driving around. I have noticed some other guys running around with 3/8 lines and I was wondering how it is working out for them. I like having the faster response with 1/2 lines and if I stick with them then I would probably do hard lines but I was wondering how extreme the difference would be in response time and such with the 3/8 lines. Also, does anyone know where you can pick up some stainless braided sleeved line that is longer than just the 18 inch ones I have seen. Thanks.
periportfd
If the line is installed so that it is possible to grind it off with 1/2"....3/8 isn't going to help you. You can get the stainless braid at any performance shop or order though Jegs and Summit.
crazeflier07
Well my car doesnt lay out so I dont worry about the line too much, its just when I'm riding low and I hit something that I am concerned about. I tried to run the line through the inside so that it wouldn't be outside but the risk of kinking the line was pretty big, so I ran the line under the car. Lucky for you guys with actual frames on your rides, you can line them with that, unlike us unibody guys! lol
s10
last post by baha +1y
