tires hit when trying to remove them
framescr8pintoy@gmail.com's avatar
framescr8pintoy's avatar
framescr8pintoy
just curious if anyone else has ran into this problem or if its just something that comes with bodydrops. i was trying to remove my rear wheel to get more access to do some work but come to find out i cant get the wheel off because it hits my bodydropped bed.i tried to twist/move it which ever way possible but it still hits the drum/axle. which sucks if i ever get a flat tire cause to me the only way possible to get my rear tires off is to unbolt the bags and let the axle hang down lower. is this common?
jason
bdroppeddak's avatar
bdroppeddak
thats why you see more mechanical advantage setups (bags on bars) because its nice to have enough lift to untuck wheels/tires, not to mention ride quality.
I
ILAYTRUCKS
Man you must have mud tires on your truck then? Anyway take the lugs off and do one of the pull the bottom of the wheel tilt the top inwards and it should come off. You dont have to pull the thing strait off the drum.
draggnrights407
u have to do the exact opp. take lugs off pull the wheel off the studs spin the tilt the bottom under the hub it should come off
framescr8pintoy
no ive got 17's with 40 series rubber and i cant tilt the bottom or the top thing.. just wondering if anyone else ever ran into this situation.
Bentlay's avatar
Bentlay
air the truck all the way up. jack the axel WAY into the air, and then when u pull the wheel forward, the top the wheel should sit on the hub, and u can wiggle it out.
