thinking about buying a pace setter header
1lowryd
should i be slapped or what? are they any good. here is the ebay link good. here is the ebay link
if not what should i be looking for?
kdcgrohl's avatar
kdcgrohl
yes, you should be shot in the face nineteen times.
There are only two good choices for 22r/e motors.
LC Engineering <--My personal choice, and
Doug Thorley which also gets good reviews around here.
cable's avatar
cable
nineteen times? in the face?Harmonic Balancer!!!!
draggin87yota's avatar
draggin87yota
i plan on gettin a doug thorely header,does anyone kno if it drags or if its above the frame?
kdcgrohl's avatar
kdcgrohl
both the LC and Thorley sit above the frame. my LC is a good inch up even with the motor dropped 1".
holcombe347's avatar
holcombe347
my thorley sits above the frame rails. its a bad ass header...looks mean too!
smctoy's avatar
smctoy
Im going to order a LCE header this week & was wondering whinch one you guys use & think is best? There are several on their site...oh & I have the 22re in my truck too with a 5-speed! Thanks guys
kdcgrohl's avatar
kdcgrohl
1041030 is what i'm using. i could not use the connector pipe due to the stock floor, everything from the three bolt flange back had to be custom. if i'd not dropped the motor, would have been all good.
assdragginsdime's avatar
assdragginsdime
pacesetter is junk. i have one. its cheaply made. MIG welded, And theres some extra holes drilled in the flange that need to be plug welded, otherwise the header will leak. The 4th pipe needs to be hammered in too to clear the rail that goes on hte outside of the exhaust flange. I honestly just bought it cus i got it cheaper than what it would cost for a new stock manifold. cus my truck was missint the whole exhaust system when i got it.. After seeing the quality, i was just gonna cut the flange off and use it to make a new one.
da_roach
where is a good place to pick up the thorley header?
