Yota 2.4L 22-RE I4 \  Make'r go fast
Make'r go fast
views 1509
replies 12
following 10
guilty by design   +1y
Thinking about putting a turbo on the yota once i get it back. Ive been hearing these 22r motors run more efficient and get more MPG with a small turbo on them. Not really looking to make the truck faster, but obviously it will be.
Whats the best turbo i should be looking for?
lowboytrucks   +1y
if efficency is what you are looking for i would think a fuel injected 22re would be better with a turbo then a carborated 22r, i have always liked holset or garrett... and they come on pretty much any factory turbo vehicle and are easy to rebuild...but there are TUNS of different turbos to fit your need...
yota93   +1y
yeah the turbo will work for you, thats the next step i am going for, i was told to use a t-25 turbo, but i also got a trd stage cam, downey header, it helps a little bit, good luck
yota93   +1y
truck action   +1y
LC , as a turbo, & I believe supper charger!
yodaforce   +1y
I've thaught about an Eclipse turbo or similar. It helps if you can build your own manifold. I'm just going to get a normal header and some j-bends, run an oil line, and try it out. I hope to find a turbo at the junk yard. If I get one out of a wreck, then atleast I know it was working.
toyotaman89   +1y
fuck a turbo.
Post was last edited on Nov 20, 2007 06:11. This post has been edited 1 times.
kdcgrohl   +1y
^that, is sexy...
toyotaman89   +1y
KDC.....they have one for the EFI engine too
twisted minis   +1y
I fawking need that!
