Yota 2.4L 22-RE I4 \  20r timing chain
20r timing chain
views 982
replies 7
outkastyota   +1y
can you put a 20r dual timing chain a 22re?
kdcgrohl   +1y
no. wrong length chain. also wont fit behind 22r cover.
LCE makes a conversion kit tho, makes it pretty easy.
outkastyota   +1y
whats the difference between the 22r cover an 20r?reason im wantin i can get one for free.i have axcess to 4 different toyotas.3 late 70s an 1 84-88.
kdcgrohl   +1y
pre 85 block is taller, therefore, chain is longer cover is taller. 85-95 are all "basically" the same.
also, just as good practice, you should never recycle a timing chain. gears maybe, guide if they're perfect, but not the chain. Toyota suggests replacement around 80,000 miles.
outkastyota   +1y
ahhh ok.oh no i wasnt gonna reuse the chains.just the gears.i just had my timing chain redone on my motor.im buildin another motor for a turbo.so i was just wondering
chinkys10   +1y
What part of NC you from and where are the yotas. I'm in need of a booster from the 79' to 83'
kdcgrohl   +1y
the booster you need is not for those years only, dont restrict your search to those. my 94 came stock w/ the small diameter booster.
outkastyota   +1y
im near fayettville.my pops lives in wilmington im there everyone once in a while.
