Chevy/GMC Trucks \  Famous S-10 Lean??
Famous S-10 Lean??
views 427
replies 16
following 17
wilddime   +1y
Whats this famous s-10 lean?? Someone told me that when you bag your 82-93 s-dime it will lean to the drivers side, nothing you can do about it, any truth to that??? If so, any suggestions on how to fix it and make it level.....
periportfd   +1y
I think its more like most trucks lean. The weight of the driver, fluid lines, wires and gas tank all being on that side cause it. A swaybar will help a bit, but having 8 valves will help the most to compensate.
AVTekk   +1y
its not with just 82-93, its all s10s. and its not even when you bag it, its like that stock and shows up more when its dropped. the newer trucks show it more than the older ones. how to fix it? put 5psi more in the drivers corner, thats what bags are for.
sonoma94   +1y
it has somthing to do with the front springs, they sell a spacer that corrects it.
the only way to correct it with bags i would think is to have one bag cup taller then the other, or like Andy said, 8 valves
periportfd   +1y
Do it by valves not cups. You will limit how low you go on one side with uneven cups. Like Dave said, thats what bags are for. The more weight, the more air.
sonoma94   +1y
ya i took a stab in the dark with the cups thing, i have juice in my sonoma so and dont have any lean at all.
periportfd   +1y
Not even gangsta lean?
bdroppeddak   +1y
if not, what about atleast a white-boy styled home boy lean??
periportfd   +1y
Not dirty souf lean?
sonoma94   +1y
