Interior \  window cranks??
window cranks??
Interior Q & A
views 338
replies 10
following 9
blackrado   +1y
how do u remove the window cranks on a 97 s10? tryin to replace my door speakers... also my headliner is tweeded and it has some brown spots in it kinda looks like where the glue has come through.. what should i use to get it clean
tofnlows10   +1y
take off the little u shaped washer
blackrado   +1y
whats the best way to get to it?
tofnlows10   +1y
i always used a screw driver and plyers (easy to lose washer)....they sell a tool at autozone just for it tho...
blackrado   +1y
thanks
chumpchange   +1y
use a rag, wrap it around the clip and pull. works every time.
3In2Out   +1y
Also, auto parts store have a specially designed tool to get em out too, should only be a few bucks if you plan on doing it a lot with stereo installs. Makes it real easy to put on and take off the clips.
idrgbdy   +1y
ya, we used to use a special tool at the audio install place i worked at. but you could use 2 small scraper tools to push it out. sometimes even flathead screwdrivers.
RARA   +1y
I have the tool to remove the clips, But a rag works better.
Ruben //RA socal
jcordova   +1y
Rag works the best.
