Ford Trucks \  Drilled or Dimpled rotors...
Ford Trucks Make Specific
views 119
replies 1
following 2
jmn444   +1y
I'm just interested in drilled/slotted rotors for looks, but I've heard that drilled can cause some cracking issues. Anybody know anything about the dimpled and slotted rotors?
Sigon   +1y
Drilled Rotors are good, so are slotted. They help keep the heat done. Drilled rotors in the past were none for cracking under heavy, heavy braking. Slotted are better for that. Also, Drilled or Slotted rotors will give you more choices.
Dippled Rotors work the same as slotted rotors pretty much, help cut down on heat but since they aren't drilled all the way through they are suppose to be better. To be honest the only company I know making those are EBC and I didn't think they were all that. I have put on Power Slot and other brands and had no problem.
