Chevy/GMC Trucks \  S10 motor mounting problems
views 244
replies 9
following 6
KANTILEVER   +1y
Just got new motor mounts, tranny mount, and new devious crossmember. Have the front motor mount bolts in but loose. The rear tailshaft trans mount doesn't line up with the hole. Any suggestions what i am doing wrong or is there a trick?
streetsweeper1   +1y
I would have bolted up the motor to the mounts, the tranny to the mount and then mount the tranny mount. If you already mounted the tramnny mount how did you know where to mount it?
KANTILEVER   +1y
Well the tranny mount that devious makes. It doesn't seem to adjust front to back. Should i modify the trans crossmember?
streetsweeper1   +1y
streetsweeper1   +1y
how many inches off are you?
KANTILEVER   +1y
one inch
streetsweeper1   +1y
not saying devious would build the mount wrong, but I would definitly cut into aftermarket parts before I would ever try changing anything else. Sorry man. that's the best I can do without actually seeing the truck... You could try cutting right where the tube mounts to the plate and re-weld it back on. is this the same part???
KANTILEVER   +1y
nope its this one http://minitruckinweb.com/tech/0407mt_drag/.
if you have yahoo or aim
YAHOO = arctichusky1
AIM = arctichusky
i am try'n to get some pics but i can't find my camera.
streetsweeper1   +1y
ouch yeah thats right they do look like that. I would just muscle it around and bolt it up in a few different orders
KANTILEVER   +1y
Well it works now. If it doesn't work cut it. I was just not wanting to cut up a bought piece, but i did. Thank you for try'n to help.
