coolant problem I need to solve it.
N
northerntoy
When I was working on my toy this weekend , I just did check the coolant and notice that I am missing alot of it . We did redone my headgasket and I there is no leak so I dont have clue where it went.
kdcgrohl's avatar
kdcgrohl
moisture out the tailpipe = blown head gasket
moisture on the ground = look for the leak
also check for "milky" oil.
SY
sd yota
also check for a bad radiator cap....... if the resivoir is full past the regular line or indicator sometimes it could just spew extra as it expands. leaky hose can also do it..... check and make sure your hose clamps are on tight. top, lower, and bypass...
3tcrob
Could also have a bad heater core leaking in the box
Moisture out the tailpipe is not always a indication if you have water coming out that just means your cat is working
phatboislim
could be something like was wrong with mine (combination of a leaky headgasket also), but my radiator had a leak on the top neck..
N
northerntoy
I already redone the gasket that's what I dont understand, I will check that out guys when I come back from Florida .
I am trying to escape the snow for 5 days.
N
northerntoy
i dont have a cat
slammedtoys's avatar
slammedtoys
Do you have a dog?
3tcrob
A fish?? Pressure test it
truck action's avatar
truck action
Take it into any shop , & have them take a reading with a smog sniffer in the water filler neck, will tell you if head gasket or head problem!!
