Air Ride Suspensions \  New Shopping List--- Is everything CORRECT?
Air Ride Suspensions Q & A
views 123
replies 3
integraoligist   +1y
Edited: 9/27/2005 10:03:38 PM by integraoligist
I've been working on this for a couple of weeks and wanted to run it by you all just to confirm that everything is correct...
Cylinders: (2) 3" for $84.55ea
-----------(2) 4" for $141.55ea
Cylinder Brackets: (1) Set for $179
Compressor: (1) ViAir 380c for $169
5 Gal. Air Tank: --- (1) Not sure yet, I hear FIRESTONE has the best?
Pressure Switch: (1) "The Green One" 145on - 175off for $15
Valves: ( 8 ) SMC 1/2" for $46ea
Airline: (50') 1/4" (for gauges) for $15
---------(50') 1/2" for $24.50
Switchbox: (1) 10-Switch Box for $32
Gauges: (4) ViAir Black Single-Needle 160psi for $10ea
--------(1) Air Tank--- Need Black face upto at least 200psi
Speed Controler/Muffler: (4) 1/2" for $10ea
Water Trap: (1) SMC 1/2" for $30
Fittings: Working on it
Here are my questions...
1. Are Firestone Tanks the best quality tanks you can get?
2. What Brand of Pressure Switch is "the green one" everyone sells?
3. Are the 1/2" Air lines the correct size for the 1/2" Valves? Or do I need to get the 5/8" Line for no Bottle necking?
4. Are there any 200psi or higher Gauges with a Black face to use as the Air Tank gauge? Brand, where to buy?
5. Is the 1 SMC 1/2" Water Trap the correct size to place from the 380c Compressor to the AirTank?
I think thats pretty much it.
Thanks all for the help!
whynotfab   +1y
1/2" lines are plenty fast unless you just prefer to use 5/8" so all of the Inner Diameters match and you might notice a difference. Might cost a little more for line and fittings though..
I'll keep an eye out for black face 200 or higher PSI gauges for your tank, and also you'll need a 1/2" x 1/2" Male Hex Nipple to connect the Water Trap to the tank, then a 1/2" x 1/4" Reducer Bushing to hook your compressor into the water trap.
About the air tank's I'm actually not too sure.. personally all of my friends and I use the regular old black ones we all see, since you plan on using a water trap and maybe a drain plug as well.. rust shouldnt be much of a problem.
soggy tacos   +1y
i took the liberty of changing th prices that i know you can get cheaper from RIC.
Cylinders: (2) 3.25" for $199.99
-----------(2) 4" for $199.99
Cylinder Brackets: (1) Set for $139.99
Compressor: (1) ViAir 380c for $169.99
5 Gal. Air Tank: --- (1) Not sure yet, I hear FIRESTONE has the best?---44.99
Valves: ( 8 ) SMC 1/2" for $39.99ea
Switchbox: (1) 10-Switch Box for $29.99
--------(1) Air Tank--- Need Black face upto at least 200psi--vi air dual needle-29.99
Speed Controler/Muffler: (4) 1/2" for $4.99ea
Water Trap: (1) SMC 1/2" for $24.99
Fittings: complete fitting pack, 99.99
1. Are Firestone Tanks the best quality tanks you can get? doesnt really matter
2. What Brand of Pressure Switch is "the green one" everyone sells? arrow i believe
4. Are there any 200psi or higher Gauges with a Black face to use as the Air Tank gauge? Brand, where to buy? vi ir 200psi dual needle
5. Is the 1 SMC 1/2" Water Trap the correct size to place from the 380c Compressor to the AirTank? will work fine
rail it customs - 661 492 1141
MEDIKATED KUSTOMS   +1y
Edited: 9/28/2005 12:32:22 AM by MEDIKATED KUSTOMS
^^^ that list is more shit for cheaper, and reliable, its quality shit, not AIM, RIC is the way to go
