Audio/Video \  JL Audio XR653CSi - JL Audio 3 Way XR Series Component
Audio/Video Q & A
views 481
replies 2
FrameLayN88   +1y
I am in the need of some help. I am looking for an amp to power these. I want to keep everything JL. The information on them are below!ThanksFrameLayN88 Isuzu-----------------------http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1190
3-way System: 6.5-inch Woofer4-inch Treated Pulp Cone Midrange and 1-inch Aluminum Dome Tweeter70W Continuous Power HandlingRec. Amp Power: 25 - 150 Watts 90.5 dB Efficiency @ 1W/1mFR: 48 Hz - 25 KHz ? 3 dB
cantlooswit22s   +1y
if you want to keep it as all jl.get the 300/4 i think it is.and run your fronts and rears off that.i think thats the comp set that i have,it on a old asz ppi 2ch amp.sounds dam good.but if your not goin to have rears.you can use the 300/2 or go with the e series amps.they are a lil cheaper.
jl audio   +1y
I agree the 300/4 would be good. If you want more power get the 450/4 I run two of those to power all my highs. XR650 Components in the Front, XR525 Coaxials in the rear.
